Corrad
Dashborad Light Not Working
Hey Me and my mate changed my factory radio in a '97 Toyota Corolla and when we finsh we noticed that the dashbord light's did not work we check all the fuse's but we can not find a way to get a round this problem and help would be much appreciated.
Could be burned out bulbs, if the fuses all check out.
When you changed out the factory radio - did you do all the work with the battery disconnected? Did you do a drop in swap (use a wiring harness, ie, plug and play), or did you do any wiring by hand / spliced any wires?
Assuming that the bulbs are fine, fuses are all OK - then that leaves any of the work from the radio swap. Depending on how that was done (wiring harness / spliced wires / battery still connected), could be almost anything.
I saw the title of this post and figured I'd ask my question here.
My boys drive a 2001 Prizm (Corolla in disguise) and they informed me the dashboard lights just stopped working. We haven;t done any electrical work to the car so I'm not sure of the issue.
I have a couple of lights in my 98 Corolla (257,000 miles!) that are out, but I can still read the dash at night. Are these actual bulbs that can be changed or are they LEDs?
Any insight would be appreciated.
