Guest eersfan
Maintenance Required
Guest eersfan
I need some help not sure whats going on, Just purchased an 09 Corolla LE with a little over 17,000 miles on it and this morning The Maintenance required light comes on. Car is running fine though, any help would be much appreciated.
That message is part of the onboard diagnostics - part of the built in motor oil timer (oil change indicator). Comes on roughly every 5000 miles or so, depending on how the car is driven - sounds like the oil was changed a bit earlier than scheduled and the maintenance timer was not reset.
In the owner's manual - there is a description that walks you through how to reset the maintenance lamp - basically a series of odometer pushes and ignition key cycling.
