Guest irvine555
Catalytic Converter Question
Guest irvine555
I have a 2000 Corolla that had a bad oil leak (it all went out the exhaust, nothing on the ground), so I decided to change the engine out. I changed the engine out, but it still has the check engine light on and the mechanic says its the catalytic converter. I get about 29-30 mpg with the car now and they don't test emissions in this part of the state (LA) when getting an inspection sticker. Do you think I need to change the Catalytic Converter, and if I do change it should I get the Universal Converter ($250) or the Direct Fit ($550). What is the real difference between the two besides the price.
Quick Breakdown:
2000 Corolla--has 110,000 miles on it
I put used 2001 Corolla engine in it---55,000 miles on it
I assume Catalytic Converter has tons of trash in it (Check engine light is on), but doesn't seem to effect MPG
They don't check emissions during state inspections
Should I get a new Cat?
If so Universal or Direct Fit?
Quick Breakdown:
Do they check for CEL?
If they do not check for emissions then changing your converter is a waste of money, but your conscience will be better, knowing you are polluting the air less.
The universal is more of a generic type and will work.
The direct fit is specifically designed for your car and is similar to original equipment.
Edited by Bikeman982
If it is really clogged with oil, it could catch fire. I guess it depends on how much. I do know for a fact that oil built up in the wrong part of the car can cause a fire. It wasn't my car, but I personally know of a car fire due oil getting on the exhaust.
If there is a chance of it catching fire then I recommend changing it. Safety should never be compromised.
