toyota81
How Good Is Your Corolla On Gas?
I agree Ti-Jean about weight, tires and aerodynamics. But on a dyno, you don't get the influence of the aerodynamics and weight (I think) factor.
They definitely must take weight into account or the test would be completely pointless (eg. the huge SUVs would get great numbers). The dyno is probably set to simulate the resistance (to acceleration) of a car of given weight and drag coefficient. This means the bigger car will have to put out more hp before the dyno lets it accelerate to a given speed. The car with the worse drag coefficient will also have to put out more hp to keep its simulated speed.
Yes, they fudge the numbers calculating losses due to coef of air resistance etc. It is calculated and not a real life test, one more reason, it is hard to beat (unless you drive with the wind).
The car has 175k km and everything is running smooth with the exception of a check engine light that comes on with the VVT malfunction code. I credit my oil change habits.
6k intervals 3 season with Quaker State High Mileage
9k intervals winter with Mobil 1
Confused, please explain:
You credit your oil habits (6-9k oil intervals) with damaging the VVT or you are saying that the they did a good job and you have only this problem?
I am curious because someone else here also mentioned problems with VVT in high milage corolla.
The numbers I have are 32/40 for a manual 05 et 32/41 for the 06.
So, indeed, I beat the US EPA's numbers at 42 for an all highway tank.
But I was below the Canada Natural Resources highway number that is 53 MPG Imp or 44.2 MPG US.
True that my tires at only 29 PSI front and 27 rear probably cost me in the neighborhood of 1 MPG.
Let me ask you, you complain that you get 42MPG? You are crazy! I get only 32 max MPG on hwy. And your tire pressure is radiculously low. I ride on 40 PSI (doesn't help with MPG).
I have just filled up after running a can of seafoam through my gas......and went from about 25MPG to 30MPG! Thats including a little top-off because I just thought no way.
That was the year and milage on the car? Was it badly carbonized? I have a can but afraid to use it!
OK.. I was waiting for enough data to add my $.02 to this:
DATE---------MILEAGE--MILES--GALLONS--MPG/TANK
07/18/2005--210--------0--------3.3120-----XXXX
08/02/2005--475--------265-----10.542-----25.138
08/18/2005--750--------275-----10.950-----25.114
09/03/2005--910--------160-----6.4500-----24.806
09/13/2005--1184-------274-----10.547-----25.979
09/24/2005--1476-------292-----10.399-----28.080
10/04/2005--1747-------271-----10.533-----25.729
10/17/2005--2010-------263-----10.410-----25.264
This is from the first fueling I did with 210 miles on the vehicle, the 3.312 gallons was to set a full baseline to start with. I use 87 octane exclusively and have filled up at different stations and have all noted in a spreadsheet for my possible arbitration with Toyota. The vehicle is a 2005 CE AT. I posted issues with this vehicle before:
See Thread Below:
https://www.corolland.com/forums/index.php?...topic=17944&hl=
The only addition to the thread above is that 2 of the 4 mounts were replaced and the vibration is 80% back. The ECM was never able to be reset by the Dealer or Toyota's regional field Techs. It was verified by Toyota that the reset process in the TSB noted in the thread above did not had a prerequiste of parts being replaced. Also the disconnection of the battery method to reset the ECM did not reset learned values.
I meet with a DSPM (District Service Parts Manager) next week to attempt one last time to resolve this before arbitration or to start the Lemon Law process.
My wife and I commute together and we travel a mix of 30%city/70%highway to work which is roughly 20 miles each way. The tire pressure is maintained at spec, we do not drive it like a race car and there is not 400 lbs of bricks in the trunk at all times.
What is pathetic is that we are cosidering commuting in our 2003 4Runner V6 again because it gets 19-21 MPG in the same driving condition with a lot more room and only at a cost of approximately 5MPG. Anyhow based on the previous posts in this thread I should be getting a *MINIMUM* of 32MPG combined.
More to come next week...
Anthony
BTW - It is not just the mileage that is the issue, the engine vibration is back almost fully now... Thanks for listening folks.
It sounds like a problem, indeed. Does its exhaust smell like its running rich?
Mine does and I only get 27city/31hwy. I also had the sulfur smell problem back in 2003. Since 2004, the gas has lower sulfur, so it's not an issue.
If I were you I would remove and clean MAF sensor with carb cleaner (careful, easy to damage). If that doesn't work, ask the dealer to hook it up to the scanner and see if sensors are working, and ask them the status of long term fuel trim. If it is negative, there is an excess of fuel delivered. Mine used to be -10%. Went down some after MAF cleaning.
QUOTE(Ti-Jean @ Sep 26 2005, 06:37 PM)
"Let me ask you, you complain that you get 42MPG? You are crazy! I get only 32 max MPG on hwy. And your tire pressure is radiculously low. I ride on 40 PSI (doesn't help with MPG)."
I didn't exactly complain but the conditions were so perfect on that day that I just expected outstanding numbers. Also shows what I said earlier about Toyota Canada getting a ringer for the official mileage figures in '03 because their number (44.2 mpg) is unattainable. The US official figure (41 mpg) is more realistic.
And why are you running 40 psi in your tires if it doesn't help with mpg?
And suffer the hard ride and risk ruining your suspension and wearing your tires in the middle?
Now that outside temperatures are cooler, I had only 28 psi front and 26 back, so I put 4 more psi all around to 32 front and 30 back but that is in my garage with temperature currently sitting at 15C while outside temp is in the 5-10C range, so I'm actually having about 31 front/29 rear for now. And that is plenty enough if you ask me, for a 2550 lbs car riding on 195/65-15 tires.
I'm experimenting with MPG display on OBD2 software I just got for beta testing. Very interesting results.
My city MPG results so far:
1st mile 15MPG (cold start, 45F ambient)
2 miles 23MPG (cold start, 45F ambient)
3 miles 26MPG (cold start, 45F ambient)
10 miles 34MPG (cold start, 45F ambient)
6 miles 40MPG (warm start)
This confirms what I suspected. Clearly, the length of trip in city has a hudge impact on MPG. It is also refreshing how idling and waiting for a green light dips your average a couple of mpg. A single WOT start and race at a green light depressed average mpg from 26 to 23 mpg at one point!
If all US cars had these MPG displays, the nation would save tons of gas.
Guest dlichterman
WHOA.....thats a great little chart thingy. What hardware/software are you using because I have been considering something like that. I also go about 11 miles to school.......averageing around 26 MPG. about half the TIME is freeway, but the freeway is 3/4 of the driving.....f-ing city traffic getting to the freeway.....
Edited by dlichterman
I use this with beta software:
http://obddiagnostics.com/
The software is still in development and not 100% accurate. Recently, I have been averaging 27-30mpg at the pump on my 10.5 miles commute (city only).
This is also what some people use:
http://www.scanguage.com/
That is a nice chart, pretty much what I found too, if you want to see the best milage you can get, get the car completely warmed up, then go fill it up, drive slow on a nice flat highway for a while, and then go back to the same pump to see how much gas you've used. Those first couple miles really suck the gas down.
My daily drive is 3 miles one way, and when I drive pretty much only that I usually see around 34MPG. I think once I got below 30MPG, but it was unusual circumstances.
Edited by GarrettSocling
The speed limit for part of it is 55, and 35 for the other half. I'll go 40 and shift into fifth, about 1500 RPM. Every little bit helps, for sure.
Yup exactly what I do. I take a slower route home from college on Fridays, and shift into 5th at 40 MPH when I get the chance. My engine spins at 1800 RPMs in 5th at 40 MPH though. Must be the ratios. 1993 Geo Prizm LSi 5 Speed manual here.
Was wondering how good everyones corolla did on gas. So far the farthest I have got on one tank is 420 miles.
I drive 700 miles per week in a 2004 Corolla LE, automatic. Consistently get 36 to 37 MPG with 98% highway driving.
Last tank was 38.9. All highway.
Edited by vurjt
