Driver side door check repair is a failure, it's too worn out and when I tried to close the door it spit one the nylon shoes out and cut into the plastic rod pretty badly. I'll order a new one tomorrow.
Also I decided against painting the chrome trim ring red, it wouldn't match the BIG HONKIN chrome door handles right above the trim rings and the rest of the chrome surfaces would also look out of place. If there was a way to do red chrome on all of the chromed plastic parts inside the car then I'd just do that but some of those parts are hard to take apart to that level of disassembly. Also a weird custom order like that would probably be stupidly expensive at any of the chroming shops that do plastic parts.
I did however still pull the door panel apart once it was off just to see how it all goes together and it's pretty easy. I also cleaned it really well while it was apart and off the car, I've cleaned before but dang I missed some stuff! The pull and in around the handle had tons of hidden dirt I got off. Now I really want to pull the other side off again to take it apart and really clean it too.
