My 03 CE had the original belt replaced for noise at about 15K by the dealer. Quieted things down for a while.
Two years later with 38K miles, there's a noise for the first few minutes in damp weather that goes away. Belt seems tight and looks fine. Less than 25K on the belt.
Dealer says this is normal and no real need to change the belt now. An honest dealer since extended warranty doesn't cover belts.
Son's 2003 LE got some belt noise around 60K. I had it changed since 60K is a good change interval for normal maintenance anyway. He says still a bit of noise but only rarely. I drove the car with the new belt and no noise at all.
So, the belt's about $120 to change. If other parts were needed, extended warranty would cover them.
Is this a common noise in damp weather? Doesn't increase with RPM. In fact, higher RPM takes it away.
My independent mechanic would use a different brand belt to possibly be less noisy.
Any advice?
