Fluid Question
By Bull6791, September 23, 2014
Fish
Just curious where do you get as INLET TYPE PUMP to flush trans fluid and how much do you think it would cost.
Frank.
I think those machines go for anywhere from $4000 to $8000, depending on features and size. Definitely not something a home owner needs, unless you plan on building a business out of it. Service time is about an hour, and they can go through 12-20+ quarts of ATF -depending on the car and how sludged up they are.
Fish
What is a pump a home owner can buy to do trans fluid flush.
I want to get one. Maybe you can give me some advice on getting one. Appreciate it.
Frank
I can't recommend any pump for the home owner - they were never designed for that in mind. They are all commercial in design - the amount of maintenance and infrastructure they need would be more than what most people want to deal with.
Best flush a homeowner can do is like the link you posted up. That will get you 99% of what those machines can do (clean oil wise) - just need more time / labor on your part.
Of course - they won't stop you from buying one. Any DIY can buy an SST, provided you have the funds - but you'll also need a pit in the garage or a car lift, to get the machine under the car - doesn't work if the machine and car are too level to each other - need that pressure differential.
Topic List
