Front wheel bearings were toast at 60,000 miles... You should be able to remove your steering knuckles to have the bearings pressed by a qualified and well equipped technician. It's too easy to ruin the bearings by not properly pressing the bearing on its outer race into the steering knuckle, and pressing the hub in while properly supporting the bearing's inner race.
It will then require a front wheel camber angle adjustment and toe alignment.
