********************UPDATE - Jan. 7th *****************************Hmm - that is a toughy. A couple of more questions to get a better idea of what is going on.So i took everyone's advice and called corporate toyota and they actually made a special provision for me to get a new tensioner for my 03 corolla outside of the 3 year, 36,000 mile warranty.
BUT... its still making the sqeaking/squealing noise as described above!! what the heck can it be ???
i have an appt. with them tues morning tomorrow and i need your guys adivce and help once again...
- this squeaking/squealing is only apparent AFTER driving for 5-10 minutes.
- it is ONLY when the car is in DRIVE with the brakes on
- i have to have the door open to hear it
- it squeals and the dashboard shakes
- it goes away when i put it in PARK
- it will stop temporarily when i turn the steering wheel
- and is DIRECTLY related to when i put the brakes on in DRIVE,
- in DRIVE without brakes = no noise
ANY IDEAS? i have an appt. with toyota tomorrow. Jan. 8th - they changed the serpentine belt, gave me a new tensioner for my 03 corolla, they cleaned my brakes... what could it be??
what do you guys think?
thanks so much again - i really really appreciate all your help!!!!
erik
- Does it do this in other gears other than drive - like reverse, or L2, or L?
- What happens if you shift into drive with the brakes depressed, then lightly step on the gas pedal (brake torqueing the car) - does it get worse or better?
- Have you tried the same thing with the A/C turned on - does it get better or worse?
- Have you tried it with the hood up and see if the engine shakes excessively when you hear the sound?
- What RPMs does the car drop to when you shift into drive with your foot on the brake?
- What RPMs do you see when the car is idling and in park?
Hard to tell without being right there - could still be a bad tensioner or belt. Some have switched from the OEM Bando belt to a Goodyear Gatorback belt with good results. Could be the idler pulley making noise - sometimes this pulley will leak grease from it's bearing - sometimes not. Could also be an idle issue - in drive with foot on brakes, idle speed should be around 650-750 RPMs - can be a little bit higher when in park - but usually around the 750-850 RPMs range (engine completely warmed up). If too low, can cause all kinds of vibrations that can kick up a resonance in the chassis or engine bay, making something produce some noise. Could be metal heatshield, bushing, or motor mount making this noise.
