i mean that there should be no rotational play. the wheel and joints and axle should all move exactly as one, not even 1mm of rotational slack.OK - sounds good.the inner joint should expand in and out, the outer joint should pivot. to further clarify, the axle should not be sliding out of the transmission, the inner joint allows the axle to change length as the suspension moves up and down. when the wheel moves up the axle gets shorter, wheel goes down the axle gets longer. the inner joint handles that. the outer joint allows the wheel to turn side to side.
I just finished putting it all back together and will be going for a test drive.
Up on jacks stands it was very quiet.
Seems like it was really bad hub and bearings.
I will find out. More to follow.
