What does Toyota include in the door (wiring and hardware) for keyless entry? I know a lot of cars have the items already "installed", just not connected. Is this true of a Corollas?
No vehicles have things like power lock actuators in the door that are simply not plugged in. That would be cost ineffective for the manufacturer.
At best, some cars use one wiring harness for every vehicle. This means that cars without certain options have the wiring for them but none of the hardware.
I don't know that the Corolla is such a vehicle as I've never taken apart any other 9th generation Corolla other than a LE model.
Hello. My first post to a forum.
I’ve got a 2008 Corolla CE without the convenience package (no pwr locks, no pwr windows, no cruise). Fantastic, smooth quiet car 35.5 MPG, in 160 miles/day use.
When I bought the car I was offered the installed alarm system which I declined – so they removed the “brain”.
I realized that the aftermarket door actuators are still there, and system wiring that was obviously added later seems to be all intact. I took a few photos of the connector and wires. The connector has a plug which appears to short out two wires – I assume it’s an ignition enable function. There is also a tiny momentary contact button (brown wires) that was unmounted but still part of the harness. There is a cluster of relays at the driver’s kick panel that are wired to the door locks.
I’d like to set up a keyless entry or alarm, whichever is easiest.
Do you recognize this as a connector as being for a particular brand of alarm? Otherwise I'll head to best buy and pay the man. Thanks for any advice.
Letting Best Buy touch your car is an invitation for disaster.
You might have the Toyota accessory alarm and need only one component to get going. Try the dealer's service dept to get a cost on activating what you already have.
If the dealer/distributor installs an accessory, you normally get a decent warranty.
Actually, if I learned a dealer put aftermarket stuff in a new vehicle voiding my warranty, I'd open an arbitration for a buyback if this were not disclosed prior to purchase.
A Mazda dealer played this game on me in 92 with a starter disabler. When I was told they cut the main underdash harness to install this, I went ballistic on them. Wound up getting the complete security system (starter disabler) installed free with a warranty. Still a bit unhappy but traded the car in 3 years anyway.
This gadget was a whole less intrusive into the car than opening up the doors and modifying the locks.
