Bitter
Hey, i have a piston with some stuck rings and I'm wondering what i can do to get them unstuck. i've tried some mechanical methods, picks, tapping with a hammer, rolling against a cast iron table while tapping with a hammer. nothing! so now I'm soaking it in ATF, i let it sit overnight in the cold (freezing up here now) and then i microwaved it for 3 minutes till it was very hot and its still soaking. if this doesn't work, what else should i try?
when i was searching i found some WEIRD home remedies for rust, such as a dilution of water and molasses to remove rust. i may try it on the crankshaft of this engine since theres some hard to reach areas of it.
if you're wondering, the engine is a 1977/78 Minarelli V1. the stuck rings and rusty crank are the parts engine which I've split and setup for testing
https://img.photobucket.com/albums/v335/huz...ed/PICT0025.jpg
https://img.photobucket.com/albums/v335/huz...ed/PICT0031.jpg
I'd like to try to save this piston since its in good shape. I've been working the cylinders lip down to raise compression, and with this mock up and a few more bolts and nuts and a aluminum head gasket i can check cold compression off the engine to see how much I've raised the compression.
