I would say it again, but I don't think you read it the first dozen or so times it has been said. The oil light on most cars is an oil pressure warningSo, tell me, Paul, what makes this Corolla consume oil so rapidly that it suffer "oil starvation?" And, is this the first Corolla owner to tell such a tale? No, he is not. There have been others on this very board, as a matter of fact.A Toyota Corolla that cannot make it between oil changes *better than recommended* without suffering major oil loss? A Corolla whose oil level got so low that the oil indicator light did *not* illuminate? Tboner claims the information says that there was only 1/2 a quart left in the vehicle, right? If so, *why* was the light *malfunctioning*? It did not come on, remember?
So, perhaps what we have here is a vehicle that has an OBD problem? Let me guess....an owner should disregard the expectation that these lights will come on to warn of impending doom? With all the high technology available, the owner needs to do *all* the diagnostics by hand?
Get real. This vehicle was *not* performing as it should.
Autoresearcher
light. It does not come on for a low oil level. The oil pressure must drop to a threshold that is lethal for the engine.
There are a few, but not many, cars that do have oil level monitors.
However, for most cars, the oil lamp going on at times other than the bulb test at vehicle start is the automotive equal of giving the dying
their last rites.
Of course, I could be wrong, so I'm happy to read an actual page from the 1998 Corolla owners manual that shows the car has an oil level warning
lamp and not just a generic oil pressure warning lamp.
Most oil pressure warning lamps are nothing more than a pressure sensitive switch, mounted in the engine block or cylinder head that provides a path
to ground if the pressure drops enough to no longer push the switch against spring. If the pressure is not sufficient to overcome the spring, the switch provides a path to ground. The light should always have a +12V and the pressure switch completes the circuit.
Some reasons why the light would not illuminate if the oil pressure dropped below the threshold.
1. Bulb burnt out
2. Fuse 12V source of bulb power burnt out
3. Faulty switch
4. Faulty wiring
There are plenty of reasons why an oil pressure light doesn't illuminate on the dash board.
However, I cannot really think of a good reason to drive to the dealership with only 1/2 quart of oil in my crankcase.
Even if I knew I was getting my oil changed, I'd put enough oil in there to get wll above the add, but not overfill the crankcase.
TB
