Guest cobrajet25
Sounds like the initial problem might have been a "double-gasket" condition on the first oil filter that Wal-Mart installed. When the Wal-Mart tech removed the first oil filter, the o-ring gasket for that filter stuck to the engine block rather than coming off with the filter. When the new filter was installed, it was installed over the first gasket. When one filter gasket is put over another, there is almost always a huge leak, though the filter will seem perfectly tight and properly installed. I did this once on my 1994 Mazda B4000 4WD. The engine puked oil like a sick maniac until I noticed it. Fortunately, I noticed it before any engine damage was done. It sounds like you were not so lucky. My guess is that this huge (but temporary) leak caused the engine to become oil-starved, get hot, and start blowing things up inside. I think Wal-Mart probably got rid of the evidence of this when you bought it back to them. Bummer. This is why you are always supposed to put a thin film of oil on the filter gasket when you install it...to keep it from sticking to the engine black. Most low-rent Jiffy Lube and Wal-Mart techs don't do this, which is why I always change my oil myself. One time, a Jiffy Lube guy completely forgot to put oil in my father's truck (he DID manage to change the filter correctly, though! ) . Only the fact that my father checked the oil before he left Jiffy Lube kept him from having his engine blow up. Anyway, sorry to hear of your misfortune, and I hope it all works out. Regards, Aaron
