Guest toyfan
My 2003 Matrix XR with 29--- miles has begun blowing large quantities of smoke when I accelerate hard and get up to about 65 miles per hour. It only lasts about 30 seconds. The check engine light comes on briefly, just flashes or does not appear at all. The dealer has not been able to get a code. They replaced the vaccuum switch valve but it did not solve the problem.
Gas mileage has dropped from slightly over 30 mpg to 27. Acceleration is a little rougher and it does not start as easily. These last two items may not be related since they began to occur before the blowing smoke problem.
Since the check engine light does not come on and stay on the dealer will not do anything.
I would appreciate any help in either identifing the cause or how to convince the dealer that they need to do something.
