Synthetic Oil
I just replaced my 2007 Corolla  with 137K miles, which was totalled by insurance, with 2013 Corolla with 35K miles. I know, based on the records which I found, that previous owner used Synthetic Oil  00279 0w201 01 0w20.  I don't have much experience with synthetic oil so my questions are: 1. are synthetic oils compatible ? and 2. what is the recommended interval for oil change? My previous Corollas used dino oil with 5k interval. Thanks a lot for any help.
Yahoo/Inbox M
There is nothing wrong with using either. You can even mix them. I only use synthetic when it is on sale at Costco. My 2003 Corolla has over 299,999 miles (odometer goes no higher).
*The important thing is to maintain the oil change intervals  as noted in owners manual.*
Congratulations on reaching 300,000
SO what would be recommended interval for synthetic oil? 10,000K?
For synthetic or non-synthetic, it is recommended to stick with interval recommended by auto manufacturer, hence using owner's manual as noted in previous comment. ...
Agreed. In recent years owners' manuals have been going much higher in terms of intervals, but I think the late-2000s would likely be six months / 7,500 miles or some such. They're available at Toyota's web site.
For Corolla 2013 Owners Manual specifies 10K under the normal condition and if you use 0-20W (which is synthetic).  It recommends 5K if you operate under special conditions, or use different oil. My previous Corolla 2007 used mineral oil with 5k interval.
