I have a 2004 corolla (9th Generation) with a manual transmission. The transmission is making a loud grinding noise when I try to release the clutch( Car does not move). It seems like the transmission need replacing but the cost of the transmission for the 9th generation is costly. The 8th generation corolla (98-2002) uses the same C59 transmission with different final gear ratio. Is it possible to swap the 9th generation c59 for 8th generation C59 manual transmission? Any help would be much appreciated.
