Yeah, as the brakes wear down - it will loosen up. But IMO, that is a pretty lousy way to approach that - as your brakes will be dragging slightly in the mean time.
These systems are self-adjusting - so every time you use the parking brake (ensures that the cable doesn't get too corroded) and backup from time to time (drum adjusting screw will turn slightly, pushing the brake shoes closer to the drum face) - there should be little needed in the way of routine adjustments.
Since they are tight - you will also be fighting that self-adjusting behavior. Only thing this will do is increase the amount of heat in the drums, could lead to issues like distorted brake hardware (clips, springs, etc. - most of the time, they are replaced with new brake shoes), warped drums, damage wheel cylinder (rubber seals), and of course - wiping what little friction material is already on the brake shoes.
I'd have them take another look - something is messed up. Or if you don't trust them - take them to a different shop. Since this is a critical safety related issue, I wouldn't just let this one slide by - for your safety and others on the road.
