I'm hoping you all can help.
I have a 2006 Corolla 2006, 1ZZ-FE engine, with 85000 miles. I've never had an issue other than new brakes with this car.
Yesterday I got a P0116 code after a rough start. The fluid is full and the car's gauge has never gone above the middle. After driving 30 miles the code hasn't returned and the gauge has stayed in the middle after warming up.
Some background.
I was told my starter was going bad last week and I replaced it. I was also told afterwards that my battery was bad and I should change it my next visit. Since the starter was changed my starts improved but were getting worse. I also found out the mechanic didn't run a test on the battery or starter before replacing the starter and though I paid for a new Toyota Starter nothing on my paper work says Toyota only " 1 New Starter". So I'm having some trust issues.
I went to Costco and bought a battery for my brother to install. When I started the car in the parking lot the check engine light came on and after driving it about 4 miles it stalled one time. I went back to the mechanic that afternoon. He did a quick scan only and said it was a P0116 engine coolant temp sensor. He said I needed to replace that sensor tomorrow and he cleared the code. No other diagnostics were performed or event data looked at.
I left and was on my way to my brother's to get the battery replaced when the vehicle stalled twice and would only start with a battery jumps. I pulled into Walmart and they changed out the battery. They tested the battery, starter and alternator and said they were all now good and that my coolant was low.
My brother checked the coolant. He couldn't add any pink coolant because it was full. We waited till the car was cold and it was still full. After driving about 35 miles on the freeway the check engine light hasn't returned and the gauge has stayed in the middle after warming up.
Has anyone else had this problem and what do you recommend, take a wait and see attitude or take it in for diagnostics even though the code was erased and there are no symptoms?
Thanks your help.
