Could someone help me to adjust the headlight AE92. The focus is too low now. There are 2 screws vertical and horizon and don't know how to rotate for the light up.
I'm much appreciated for your help in advance.
pat
by patsuper64, June 9, 2014
pat
Assuming these are similar to those on a Camry and 4Runner that I used to have - newer Toyota don't have any adjustment screws anymore. Those screws should be tied to a plastic geared shaft - vertical should control the up/down, the horizontal one does left/right. Can use a 10mm socket or use a #2 phillips in the slot at the top as directed by the FSM.
You'll have to play around with those screws a bit. Possible that you might already be at the maximum travel, as there isn't a whole lot of adjustment there. So best to figure out how much total travel you have, might have to shim up those headlamp assemblies to get them to point where you want them.
