my 2006 sounds like it has a flat tire. I thought is was a tire so i replaced all four. The sound is rythmic with the rotation of the tires. It is coming from the front end and it is worse when turning to the right, however its constant upon acceleration. It stops if i turn left. It does not stop upon letting off the gas it just slows the noise down with the speed of the car. i was told that the lower control arm is loose. would this cause such a noise.
