Fish
What type of oil filter wrench do you use. I want to use the Purolator pure one PL10241. It is the V6 filter. I just can't find a filter wrench that will fit it. Some one told me 73/74 mm. They said depending on what type of filter the 73 mm is to tight and you will have a hard time getting wrench off the filter. Also if you use the 74mm it is too loose and you can't get filter off at all. So do you happen to know what wrench fits this filter.
How do you like the OEM Denso filters. I heard they are not good.No end caps and a rubber ADBV. Just generally poor construction. If you like the Denso oil filter I might try it. I would use the biggest one that would fit on car. Also I would need an oil wrench for that filter.
Some one gave me a Rite fit oil filter wrench years ago. It is type F and A255 also 65/67mm.
I do not what filter this wrench fits.
Frank
