You can change to synthetic and back to conventional motor oil anytime you want. There is no flush or cleaning phase required - just change the oil like you planned to. On typical oil changes, most of the old oil will drain out, only a small fraction of that old stuff will be left. The additive package in the new oil should buffer it enough that that residual oil will not impact a UOA test. Might be worthwhile to try an oil before you pull the first UOA. I've had experience with some synthetics that sheared up so much, that my overall MPG dropped a sizeable amount.
That oversized filter should work - it is wider than the OEM filter, so you will have to double check that the flange on the bottom of the car is clean and pristine before you go to that filter. Otherwise, it will leak oil.
On my cars - there was significant corrosion on the oil filter flange due to winter salt - so I couldn't use a larger filter without doing some machining first. I ended up using the "tall" filters. Ones that have the identical specification of the OEM filter - just runs 1/2" taller physically. For my application - the extra height of the filter media was enough for me to run my extended oil change interval.
Extended oil change intervals have to done methodically to prevent potential engine damage. Not all engines / situations can do extended oil changes, regardless of how good the synthetic motor is touted to be. Some people baseline their engines very carefully, some pulling samples every 1000 miles to gauge engine oil life. Something I was originally planning to do - but was very cost prohibited in my opinion (case of diminishing returns). So I opted to pull a sample at my usually oil change interval - 5000 miles. If the oil was still OK, I'd left it in there and checked again at 10K miles. From there, I pushed on to see how far it could run. Note that even with the same brand and viscosity of motor oil in the car - sometimes you can run to 15K - 18K miles no problem, next time, it might only hold up for 7K miles. That's why the 5K oil change interval was adopted - long enough to help offset some costs - but short enough that there is a very low risk of any oil related problems.
I could not recommend just running to 10K miles on synthetic without pulling a prior used oil sample - as that is just too risky, especially in engines that have been known to have oil consumption issues. Driving conditions could merit a shorter drain interval - mechanical problem could pop up that could shear down the oil much faster than normal. But it is ultimately your decision to run a shorter UOA or not.
In any case, with Blackstone Labs - they actually wrote up their take on the oil life. So if you pull the oil sample at say 5K miles, they'll tell you what they think the oil can do and when to sample next. Terry Dyson at Dyson Analysis also gives you his take, being an independent UOA consultant, some owners value his interpretation more - as such, his tests also cost more than Blackstone.
