I'm planning on changing both the front struts by using the "quick mount fully assembled" struts for a 2000 Toyota Corolla. I followed the strut change video on youtube and it looks simple.
Can you verify this procedure?
1) Take off tire
2) Remove the bolt that holds the brake line
3) Remove the two bolts that hold the strut to the "wheel hub"
4) Remove the 3 top bolts under the hood
5) Pull out the old strut mount and put the new strut mount and put in the 3 top bolts
6) Attach the strut to the "wheel hub" and put the two bolts on
7) Attach the brake line to the strut and put the bolt
That's all that's required right? I also saw some mechanics put a marker where the strut was attached to the "wheel hub"....why is that? Surely that can't be for alignment right because it's in the same position when you put the new strut??
Since I have no mechanic experience, can you tell me all the tools I need for:
1) Remove the lug nuts
2) Remove the 2 bolts from strut
3) Remove the brake line bolt
4) Remove the top bolts for strut under the hood
I don't know what type of wrenches are required for each of the above. For the bolts, should I torque them to 89-94 lbs?
