...it will be interesting to see when the maximum MPG occurs. I always keep a fuel log for my automobiles, and I'll keep everyone posted as to what happens.
Hi, everyone. As promised, here's an update.
#) elapsed distance in miles -- gallons consumed -- mpg
1) 313 9.1 34mpg
2) 334 10.1 33mpg
3) 338 10.6 31.9mpg
4) 343 10.1 34mpg
5) 345 11.3 30.5
6) 396 11.7 33.7
7) 418 10.5 39.8mpg
My first tank of fuel (miles 80-313) yielded 34mpg with me babying the engine and the car now has 2580miles on it. That translates into six tanks of 87 octance BP gas, or ~33mpg. However, that last tank of fuel delivered darned close to 40mpg! So what changed? Well, the weather has turned cooler, so I'm not using the air conditioning. Plus, I raised the tire inflation pressure upwards from the 23psi when it left the dealership to 30psi which likely reduces the rolling resistance.)
With almost 2600 miles, I believe the engine is broken in at this point even though the mileage doesn't really reflect a trend. Perhaps there's a reason: in the beginning I was especially gentle on the throttle and did mostly in-town stop-and-go driving to give the brand-new engine a chance to see lots of different rpms. After 1200 miles, I started taking the 70 mph interstate highway commute to work; taking the RPMs up around 3000 with an occasional downshift where necessary. After 1500 miles on the ODO I was taking the the engine up to the occasional 4000RPM spin. Now, I just drive it without much regard to engine speed.
As far as noise, I'm not sure whether the engine is quieter or I've simply adjusted to the sound. The cabin volume is acceptable while cruising, though it's a little harsh while accelerating at more than 2/3 throttle or anything over 3200RPM.
Overall, I'm very satisfied with the car -- it's a superb commuter machine. Not a lot of fun to drive (my previous car was a supercharged Mini Cooper S) but for the most part it's an extremely well executed package. The driver's seating position is a little strange -- I feel like the pedals should be about 6" further away in order to be comfortable (or give me a telescoping wheel), and the automatic headlights are just about the most annoying thing I've seen since the 2000 VW Beetle stereo which beeped LOUDLY through the speakers when the volume was turned down (what were they thinking?). Given how well the rest of the vehicle works, I'm willing to overlook those shortcomings.
No problems to report, except that I've heard a metallic "clunk" a few times when dropping the transmission into gear after a cold start. Perhaps a CV Joint or loose engine mount? I'll have the service dept. give it a look at the first checkup.
Overall, though this Corolla is proving to be a solid package; Miserly fuel consumption, low insurance, inexpensive MSRP, and legendary Toyota reliability. That's a combination I can live with!
I'll post again after a few thousand additional miles. Looking forward to more driving to see if the (nearly) 40MPG continues!
Cheers,
Jon
