SR5_HEC
Is there any way to bypass fog lights or put them on Separate switch ?
I'm thinking of adding H.I.D Kit to Fog Lights With Yellow Lenses .. like the one ones below.
By
SR5_HEC, March 6, 2011
SR5_HEC
Not quite sure what you are after here. Fogs are on a separate switch on the headlamp control stalk (one/off ring) - unless you have a non-OEM setup.
As for the yellow lenses, could go with either a lower color temperature to get a yellow light or use some yellow overlay. Note that the light pattern will be pretty bad - will be bright with a HID, but don't count on that halogen reflector throwing light efficiently.
