Guest Mattfugs
I have a 99' Toyota and I have a problem with the power locks on the driver side. It started with the power lock on the driver's door would not open when I used the alarm button. Then the lock would not open when hit the button on the door. I would hit the button a couple times before it would open. Now, it does not work at all when I hit the button. (Please note the lock opens only when I put the key in the lock) Now the rear drivers side lock does not open at all, either using the key in the lock or the hitting the lock button.
Also, the locks do not automatically lock when the car goes into drive.
Is it a fuse or related to the alarm (not a Toyota) or something different all together?
Any help would be appreciated.
Matt
