You might want to give a ballpark budget. There's a wide spectrum of options in an even wider spectrum of costs...
Assuming you are focused on acceleration (braking/handling not included):
The 2ZZ engine itself is pretty much optimized, but there are minimal gains attainable by increasing intake and exhaust flow. Forced induction provides big gains, but costs significantly more.
Cheap/near free options:
- Make the car lighter. Remove unnecessary weight and/or begin removing unneeded interior
- In warmer climates, throttle body coolant bypasses are an option. Not much to be gained, but it is easy to do and costs practically nothing.
Works on any car:
- Lighter wheels and tires. If you have to spin up four giant flywheels to accelerate your car, might as well make them lighter.
Improving normally aspirated performance:
- Header ~$300+
- Higher flow exhaust (likely that performance gain is more from having a lighter muffler than better exhaust flow)
- Larger throttle body ~300+
- Improved tuning (piggyback or standalone ECU replacement) ~$500-3000 for hardware, then add tuning cost.
Lotus manages about 189HP from the same engine with a more aggressive tune and simple headers (not sure if it is the same throttle body).
Forced Induction ($):
- The 2ZZ internals are strong enough to handle moderate boosting. Lotus uses same internals on the supercharged Elise/Exige variants - up to 265 HP.
- I have a friend that ran a 2ZZ with stock internals (only added stiffer valve springs) over 400HP:blink:
- Cost depends on build. Understand that "kits" that do not include injectors, (likely)fuel pump, and ECU remapping or replacement will require that at extra cost.
- Lotus Elise/Exige owners can buy supercharger kits from ~$4000(~250HP with ECU reflash) - $7000(~300HP with standalone ECU). Giant shoehorns to make it fit in an XRs not included (would require custom brackets, etc).
