I have a 1999 Corolla with auto., power windows and power door locks. Someone recently touched the car making the factory alarm go off. I discontinued the alarm by unlocking the driver's door with my key fob. Since this event the only power window that works is the right front, both from the master switch at driver's door and the right front door switch. None of the power door locks work except from the right front switch--that switch now operates ALL the locks. I checked the power window and door lock fuses, and they look fine. I even replaced the P/W fuse just in case. The fusible links look good. I did not check the power window relay, as I couldn't find it. Any ideas?
Thanks.
