I've mentioned this in a separate thread, but it was totally off topic there so I thought I'd post specifically about this issue and put it in the right place (although in noticing that the last post in this sub-forum was from Feb., I'm not too optimistic about getting many replies). First some basic background:
Car was purchased from the original owner in early May of this year with 96,000 km on it. She had every invoice for all work done on the car, and even had them sorted by shop and organized chronologically. Anyway, I recently noticed sludge on the crankcase cap, and when looking inside the oil fill hole, I could see it baked onto the crankcase and some loose deposits clumped there too. This was roughly 500 km ago. My theory as to what caused it:
1) She missed an oil change at about the first 50,000 km mark, and had driven it 1,200 km on dino;
2) She otherwise changed the oil regularly, but followed the regular service schedule instead of the severe schedule she should have followed (I'll elaborate bellow);
3) Her OCIs were 4,500-7,500 km with the exception of the missed oil change;
4) Her driving habits consisted mainly of short inner city, stop-and-go trips, without much highway driving;
5) She used to the remote start to "warm" the car in the winter, and it may have spent up to half an hour idling while "warming" up.
I think those factors created the sludge (I've only had it for 7,500 km since, all spring and summer driving and a mix of 50-50 city and highway with very little idling), but at any rate its there, its clearly visible, and my goal is to remove it as gently as possible with a clean engine being the outcome. And without doing a tear down and rebuild as I don't think, despite the presence of sludge, its warranted. MPG is good (30 mpg+), performance is good, and the only issue I've had is an unrelated cold-start problem that I'm pretty sure is the IAC valve (where its summer, and I'm pretty sure this is the cause, its not yet a priority).
Oil was changed by Toyota about 1,000 km ago using their Toyota shop oil. They forgot to change the filter, and rather than wait around for them to put it back up on the ramp, I let it go to do myself. About 100 km ago I swapped out a Honeywell Defense filter with 4,200 km to a Mobil 1 extended performance filter. A fair amount of oil spilled during the change, so I topped it most of the way with the 750 ml bottle of Castrol GTX I had kicking around. With the sludge and what not, I decided to pick up some synthetic to use as top up and blend into my next oil change. Walmart's daily rollback that day was Penzoil Platinum, which cost only a couple bucks more than the leading dino brands (except Castrol and Supertech dino, which were also rolled back that day). I put the 250 ml of PP in the crankcase just to bring it to the full mark, and then set the 4.4L jug aside.
On "bobistheoilguy" I found a very old thread where a poster had a sludged Dodge with a lot more miles on it than mine. I believe the engine was a 3.6L V6. His idea was to use a blend of Penzoil Platinum to desludge it, blended with 1L of Valvoline MaxLife to preserve and condition the seals, etc. Of the 9 or so responses he got, the consensus was unanimous that his plan sounded good, and only one person voiced an objection; not to the blend, but that he thought 1L of MaxLife was too little (the others disagreed). Unfortunately, there was no folllow up post from the OP; however, the theory behind it seems sound to me, and even though my odometer hasn't hit 120,000 km, it does burn some oil.
With all of the above in mind, I'm thinking along the lines of an early OCI at about 3,500 km to get the Frankenblend out and put something in to tackle the sludge. I plan to leave the new Mobil 1 filter on and use 3L of PP and 600 ml of the newer 100% synthetic MaxLife. Right now that ratio is still being debated and I may up the ratio of MaxLife, but if I do it won't be beyond 1L. I will run that blend for about 5,000 km (if I go ahead with this plan), then change out the oil and filter.
Any holes in this?
-Spyder
