Guest tony
Had problem with ignition lock failing to turn. Removed barrel with a view to get it fixed by locksmith or replaced off breakers yard.
Unfortunately (seeing lock exposed i guess) some petty thief tried to steal the car ripping off the black ring (transponder?) that goes over the top of lock barrel thinking they could put tool in lock / short wires, but battery had been disconnected anyway! The black ring had vanished along with the unsuccessful thief.
My question is having got a replacement barrel if i get a black ring (off a '98 breaker) and connect the two loose wires to it and put it back over the barrel, will this just work?
Thanks in advance, Tony
