Hi guys,
I have a 2003 corolla AT that has been a fine automobile for 120k. Just recently I have had issues. I live in Texas but this past winter I took a 1200 mile trip up to ohio. When I went up there the car was great, getting near 40 mpg, slight vibrations had started( I figured the engine mounts were going) and the check engine light had been on for a while because of the rear oxygen sensor/cat. I did not want to get this fixed at the local toyota dealership do to price so I took it to a shop my family has been going to in ohio for 20 years. They did a 120K service including the cat and oxygen sensor. They said the sensor wire was pinched, so they put a new one on the light came on again so they replaced the cat, no light, great....... Then the car got hit while parked and ended up in the body shop for minor drivers side front end damage.(new bumper, headlight, intake resonance chamber.....)
Now the problems start. No check engine light, but the car is now getting 32-34 highway mpg and 22 mpg round town. I ran it, changed oil and transmission fluid, reset the ecu. Still bad gas milage. from 36-40 to 30-34 highway and 30-32 to 20-24 around town. All the while the engine vibration has been worsening with miles. I had a fuse blow out on me in New Mexico, only to find the body shop had not hooked up the primary ground from battery to chassis. took it to the toyota body shop where they promised to check everything including electrical. I have just now discovered that though it appeared fine after the toyota shop, the airbox is missing a bolt and my hood is not closing all the way.(bout a half inch gap at the nose, can push it to the right spot but wont hold.) So the car needs to go back to the body shop. In the meantime I took it to a shop here in texas to look at it under a Napa repair warranty. They found nothing wrong with the car, had them replace the front O2 sensor. Drove the car back to ohio, same shop as before. They looked at it, could not find anything wrong, asked them to replace the motor mounts. They only replaced the front and rear lower motor mounts(said that they where visually damaged), at idle the vibration has become horrible, especially in drive with the brake on. I have read that the passenger side mount has been a problem for some, I wedged a crow bar in, does not seem to make a difference, though I would like to replace the other two mounts, cant wedge a crow bar in the drivers side mount.
My friend suggested that I might be losing a cylinder at idle, so I checked by unplugging each coil, engine appears to be running on all 4 cylinders at idle.
I plan to do a compression check for myself and plan to do at least the passenger side mount if not the other.(hopefully that fixes the vibration)
Do you all have any ideas what could be causing my fuel milage issues? To much of a coincidence that it started after the 120K service and body shop, has to be something one or the other did. What else could have been misassembled in the airbox area? Could a shorting ground fry some electrical components? I guess I will look at the mass airflow sensor next....
I am hoping the other two mounts fix my vibrations........
Thanks for your help!
Andrew
