Guest peanut1986
Hi,
I am experiencing a issue with my 1999 toyota corolla automatic starting, along with that, when i turn the key to acc or on all the lights in the dash come on really dim and radio is off, but the light brighten back to normal within about 20 seconds, and after that 20 seconds the radio turns on, but when i go from ON to start it's like it dumps the power and the lights go dim again then start to gradually brighten,, I started with the basics,i got the battery checked,, GOOD,,i got the started checked,, GOOD,,i replaced and cleaned every grounding stud in the engine,, i did a resistance check from the battery to the starter it was good, i checked my fuses, all the see through ones are good, i replaced the starter relay, it made no difference, i checked the ignition switch, it seemed perfectly functional. So now i am stuck on what else it can be.
The car starts perfectly fine when jumped, which in my mind is more confusing.
i'm starting to think the problem isn't necessarily the starter and thinking more about how the power seems to be inconsistent.
