Hello corolland members!
I am new here to learn and ask questions about (my daughter's first used) 2000 corolla LE.
One question I have is how to remove the plastic steering column cover to get at the screws for the turn signal/headlight lever switch. (The switch is causing a rapid turn signal sound when signaling left only.)
I have removed a single phillips screw from the underside of the cover. But I can't seem to jostle the two halves of the cover apart.
Are there more screws holding the cover on that I can't see?
Thanks for your replies!
Edit:
I think I figured it out now. By turning the steering wheel, I can see two more screws. I will try removing them.
I am hoping to clean the electrical area of the left stick with electronic spray. This may solve the rapid signal problem which is only periodic.
