Valvecover gasket replacement is a piece of cake. The only additional item that they recommend is a little dallop of FIPG material right where the timing chain cover meets the head to prevent any chance of leaks around that area. Some do it, some skip this step - from what I've seen in both cases, to leaks where reported. You're more likely to get a leak around the timing chain tensioner than a leak at the seam where those components line up.
If I remeber correctly, should be 6 - 10mm bolts around the perimeter of the valvecover and two 10mm nuts at the front corners, there are also two 100m bolts on the top. Just check around the perimeter of the valvecover - pretty hard to miss the bolts/nuts holding it down. You may have to loosen the cable bracket on the side as well - should be pretty apparent when you look at it. Also have to pull the spark plug wires out of the way - note their location, just incase they come loose from the coil packs. Their length should help you avoid getting the firing order screwed up - but make notes/take pics as a precaution.
Plugs can be left in (they do not hold the valvecover down) - but I generally remove and replace them when it comes time to replace the valvecover gasket. Might also be a good time to check valve clearances once you have the cover off - if you are feeling adventurous.
Valve clearance? Is there a DIY some where I can refer to? I would need the feeler gauge right?
Thanks,
