Bad_dude
It's about 30000 miles since my last transmission oil change. The last time, which was 30000 miles ago, the pan was dropped, clean and fluid refilled. Since I want to do it myself this time, could I just drain and fill and NOT drop the pan since I don't see any leak? Which type fluid should I used? Does the new fluid have to be Toyota brand? Does this car just have one plug and fill or does it need differential oil change as well? What size and type of tool I need to take the drain plug nut off?
Thanks,
