Driving a 98, I'm pretty sure the first owner either took crap care of it, or it sat too long somewhere, because I burn oil like crazy. I'm trying some AutoRX to see if it cleans out, but if my replacement of the speedometer cluster takes care of my left signal/defrost problem, I'm going to assume the car has more miles than stated. (I bought it with 70,000 on the odometer; if the cluster was in fact replaced, I doubt they swapped ODs.) So I'm mulling over the idea of replacing the engine.
My question is, I know you can update the engine from non-VVti to a newer engine with it, but how many years are useable? I saw at toyota nation that someone used an 07 in their 01, but what's the cutoff year? Are the engines about the same size, and can they be swapped without fabrication to make them fit?
Also, I want to make sure I understand: when you do this, you need the engine, the electrical wiring, and the ECU, but what else is there? I'm looking at swapping from a new Corolla, so I'm not sure if fish's explanation here still fits, as that was between two entirely different car companies and models?
