I had posted back in the spring about the car. The car ended up coming with 4 studded snow tires (in addition to the relatively new all seasons) and he had done a complete brake line replacement, brake job, suspension (shocks/strut/etc), air condtioning test/recharge, and even an oil/filter change before I purchased it.
The car is a trooper. I got it with roughtly 199,000 miles on it. My daughter got her license with it and the studded snows have been a blessing this winter.
The oil consumption hasn't been an issue. When I first got the car I replaced whatever oil needed to top it off with Marvel Mystery Oil. I also put some in the gas tank every once in a while - a couple of ounces. Then I changed the oil at about 1000 miles of having the car - by that time the car had joined the 200k club.
So the car has been driven roughly 3000 miles since that oil change. I didn't even use a full quart to top things off in the meantime. The oil consumption appears to be getting better since I got the car. I believe the Marvel Mystery Oil cleaned and loosened/lubed things up. I'll know more the next 3000 miles.
Question about engine light code. In the week before we got the car - we came to terms with the owner and exchanged some money - the engine light came on. Up to that point the light had never come on or been an issue. He checked it and replaced a valve under the hood by the power brake - something with the emissions similar to the one near the gas tank - and put a genuine Toyota gas cap on. He did this at his cost. We had the car for a couple of weeks and the light came on again - checked the code - the dreaded p0446/p0447 and another one to do with a sensor by the catalytic converter. So I pulled the battery cable to reset it, she passed her driver test, and the light came on again in less than 100 miles. He said he would take care of it at his cost, but we were never able to get together.
That was back in May. I never did a reset of any type since that point and the light has been on the whole time. The fuel mileage has been great and the car starts and runs without any issue. I recently realized that the car needed to be inspected and had yet to address the engine light/emission code issue. Neighbor is a mechanic and would fix it - he ran the diag and the same 3 codes were coming up. I pulled the battery - which I hadn't done in 6 months - did a reset and had my daughter drive about 40-50 miles before the inspection to reset the sensors and it passed without any issue. The mechanic even commented about the overall mechanical condition of the car.
Here is the odd part - the light hasn't come on in the nearly 6 weeks since the reset. It's driven every day and been fueled up a few times as well since the reset. I don't see how it could have fixed itself, but I'm not complaining.
Is it possible that something in the battery pull that finally did a complete reset?
