Please HELP. I'm not anywhere near of being a mechanic. Here's my issue and I hope someone can help. I have a toyota corolla year 2000. Here's a quick story of what happened: Car started acting up at (170,000 miles) it would turn on then it would hesitate and then turned off. Borrowed an OBD11 tester and it came up with a missfire on cylinder 2 and Maf sensor. I didn't have the money to fix it, so the car was left alone for about 2 months. I would turn the car on every 2 weeks or so. Left town for 3 weeks, when I returned my dad told me that a mechanic said that the engine was bad and that had to be replaced. My dad agreed to it. According to the mechanic he put in a newer engine(Not sure what year, but with 60,000 miles) Yeah we got screwed, my dad ended up paying him over 1000dlls.
With that said, the car turns on and idles rough! It's at 1.5 rpms and I don't know how to bring it down. In fact there's a connector missing on the top of the throttle body. There are three sensors the one at the top which it doesn't have a connector( according to the cheap mechanic, it doesn't need it.. I think he cancelled it or something) the TPS which is located to the bottom left side of the throttle body and the third which is to the right. That's one problem the second problem is that it vibrates excessivly while in drive(at a complete stop). I can feel all the vibration on the steering wheel, it's annoying and I'm tired of it.
I went and did some research online. First thing first... the oil, sparkplugs, sparkwires, pvc valve, air filter, oil filter are new, cleaned the maf sensor, checked transmission fluid and reset the computer. Car turned on fine but with a rough idle and it's been like that eversince. Connected the obdII sensor again and got p0171 bank 1 lean.... (Not sure what that is) What really bothers me is the exessive idle and vibration. I dissconnected throttle body from the intake manifold and cleaned it I also disconnected the TPS sensor and cleaned it and noticed that there is a small wheel bearing inside which it was completely corroded. I cleaned it the best that I could. Now, don't know if the bearing which has a small shaft with a magnet attached to it supposed to turn or not. If it does it didn't turn! and if that's the case I think I will have to buy a new TPS Sensor. I reinstalled everything and the car still idles rough (1.5rpms) and the car still vibrates when in drive while stopped on a light, it stops vibrating immediately when I step on the gas.
A friend says that the problem resides on the motor mounts, but I checked them and they seem fine, but again I might be wrong. Any advice would be of great help. Thanks
