Hello and Welcome to the forum.
Unfortunately, could be a number of things that would cause this issue. Need a little more information to help point you in the right direction.
When you turn the key to start, did you hear the starter relay make a "clicking" noise? Have you tried restarting the car, anything happen? Anything different happened? When you say everything died, did you mean after you turned the key to start - nothing electrical worked after that point on? Lights? Dash display? Radio, etc.? What still works? What doesn't work? How did they test the battery - just the voltage, or did they load test the battery?
Could be a bad fuse, most of the bigger ones are under the hood - starter, EFI, alternator, etc. Could also be a bad relay, faulty electrical connection(s), could still be a bad battery. There is also a fusible link block (the alternator's 100 amp fuse is part of it) - which is basically a big wire/fuse block - that almost never goes bad, but it if burned out - you may have a more serious electrical problem with the car (dead alternator, one of the main source cables is shorted, etc).
