Group
I have a 2000 Toyota Corolla and installed a 2004 Corolla engine two weeks back. About 5 minutes after driving the car the code P0420 came up. I have had the code reset several times only to have it return after a few miles driving. This code never came up with the old engine, this only started after installing new engine.
Car was warm when testing the O2 sensors
I have checked the upstream O2 sensor, it has a 4 wire connection
Wire readings
1. Black 1 0.368 volts
2. Black 2 0.058 volts
3. White 0.01 volts
4. Blue 0.1 to 0.8 volts
I have also checked the O2 sensor located after the convertor, it has a 4 wire connection
Wire readings
1. Black 1 13.65 volts
2. Black 2 0.417 volts
3. White -0.017 volts (negitive reading)
4. Blue 0.086 to 0.800 volts (range)
Dont know what the readings should be
Any help would be great
Thanks in advance
