Is it just me or is the search button missing?
So my CEL has been on for quite some time now and I've slowly been tinkering with things in hopes it would go out. It first came on months ago intermitently and gradually stayed on longer and longer until it's just always on. Now that my Inspection is due I Need to git er done.
The code is P401? (or something like that) for EGR insufficient flow. I checked the Egr valve and the vacuum switching valve operation and cleaned out the egr valve but the light stayed on. (VSV ichecked flow/no flow as is and with 12v applied it clicked and the valve switched states. The egr valve seemed to open ok with a slight vacuum and maintain the vacuum over time so I'm fairly comfortable there's no leaks in the diaphram. It also held fluid (sea foam) fine until vacuum was applied and then it seemed to flow fine.)
I replaced the modulator valve and after 3 drive cycles the CEL went out. Perfect!
UNTIL literally the next afternoon the CEL lit up again and sure enough it's again egr insufficient flow with the same code pending ???
Oh, this is a 99 camry by the way, 4 cylinder.
PS if anyone knows the engineer who designed the VSV and ERG valve in their locations on thes car .. I'd like to have a few words with him/her. Gogo Gadget Rubber Arms. I'm an engineer and if I ever design something that hard to get at without a damn good reason ... Please shoot me.
