DaRi_GJ
Hello,
I've seen many posts about vibrations, but I really wanted to post about this problem because my Corolla 2002 (automatic, CE, 101K miles) has an additional situation, besides vibrating when stopped.
When I turn it on in the morning, after about 6-7 second it starts vibrating a lot more than usual (extremely) and it even turns off sometimes.
I've had turned it on again, and the same occurs. I have noticed that if I step on the accelerator just a little bit and even for just 1 second, the vibration might continue, but the car doesn't turn off.
I mean after the engine is hot it has an annoying vibration many people have been posting about, but besides that I get an "earthquake" when I turn it on (when the engine is cold). Like I said if I accelerate it just once it doesn't turn off. And vibration is a lot worse when I turn on the A/C, when the engine is hot there's no problem turning on the A/C.
I changed the sparkplugs, cleaned the TPS, ran an injector cleaner with a full gas tank, changed all defective mounts, etc.
Any suggestions about this problem???
