I'd stay away from OBX products - especially their header. On the earlier 9th gen Corollas (2003-2005) - they wouldn't bolt straight on without some modifications.As for the later 9th gen Corollas - they can be tough to find. I don't remember off hand - but I believe that your model year has the pre-cat welded directly to the exhaust manifold. That could be why you are having problems finding a bolt on aftermarket header. The ones that have installed a header (PPE header - custom made, runs about $900+ depending on coating) - they have to eliminate one of the cats or both - could be a problem for areas that smog. Shops are obligated to call those modifications in or won't even touch them in some area - so check ahead before you invest into a header.
One option that has proven itself on the dyno is to port the OEM header. The OEM piece is tubular exhaust design , not the cast log exhaust type of older cars - an experienced fabricator should be able to port it for less than the OBX header you were probably looking at. Gains would be better than stock and fitment would be perfect - since you are using the original part. Plus, from the tech point of view (smog test) - everthing looks OEM/untouched.
Thanks for the info. I'm going to take a look today to see if it's welded or not. I was told that JP Performance has one for the 2007 so I e-mailed them to see if it's a bolt on or if I have to take it to a place to have installed
