you can use either one . Just remember that pink is pre-diluted.
I would use red myself. flush it every 3 years . pink is overkill except in a new car.
Toyota has 2 types of coolent, Red and Pink.
The red is a long life and the pink is a super long life.
Do not mix them and do not mix in green.
The Pink is premixed so you can just pore is right into the motor, the Red needs to be mixed 50/50.
Toyota 50/50 Pre-diluted Super Long Life Antifreeze/Coolant (pink color)
Factory-filled pink fluid specially formulated by Toyota for Toyota vehicles
50/50 Pre-Diluted formula does NOT require the addition of water
New generation ethylene-glycol based premium engine antifreeze/coolant that offers excellent corrosion protection
Contains water, ethylene glycol, diethylene glycol, sebacic acid, & potassium hydroxide
Protects from -34ºF to 265ºF (using a 15 lb. psi pressure cap)
Meets all Toyota warranty requirements & ASTM Specs
Available for in-store purchase only.
Toyota Long Life Antifreeze/Coolant (red color)
Factory-filled red fluid specially formulated by Toyota for Toyota vehicles
New generation ethylene-glycol based premium engine antifreeze/coolant specially formulated for all Toyota engine cooling systems
* Helps prevent cold weather freeze-ups and hot weather boil-overs
Does NOT contain silicates that may harm water pump seals
Does NOT contain borates that may cause aluminum pitting/corrosion
Provides excellent corrosion protection
Contains ethylene glycol, diethylene glycol, water, organic acid salt, and hydrated inorganic salt
