Hello and Welcome to the forum.
You mean that it doesn't seem to be blowing any cold air? Could just be low on charge - there is a sight glass window that you can take a peek at as the A/C is running. Should be clear and with no bubbles - be in the front of the car, close to the radiator - just look for the large metal cylinder with metal hoses running to it - there will be a little window on top.
Otherwise, do the pressure test - that is the quickest, sure-fire way to determine if you are low on refrigerant. Those little cans they sell will recharge your system just fine - but you have to check the pressure first. Very easy to overfill the A/C system and cause problems down the road.
Two things I woud check out first: Check the cabin air filter - make sure that is clean, otherwise replace it. If that is clogged up - will seriously reduce cooling capability. Second, make sure the A/C compressor is actually coming on. With the hood up, flip the A/C on and off - you should note that there is a pulley that only turns when the A/C comes on. When switched off, the magnetic clutch will just allow the pulley to free-wheel. You should also note that the idle speed will jump up when you switch on the A/C, if it doesn't - the compressor make not be working (most common cause, is low refrigerant levels - A/C will NOT run to protect itself from damage).
