I am going to attempt to convert a 1999 Toyota Corolla LE (manual) to an electric. An option is to go "Clutchless" as the Electric Motor is content to go to ZERO RPM at stops... and because of the wide power band of electric motors, shifting is infrequent. Most local driving is done in 2nd, with a shift to 3rd for highways.
That said, I will need to find/have made an adapter from the Transmission input shaft to my Motor output shaft. I have the specs and dimensions of the Motor shaft...
Can someone point me at where to find the Transmission Input shaft specifications?
thank
