Hello and welcome to the forum. Is this a US spec car? As they have a Corolla "Sport" overseas that is completely different than the North American Corolla "S" model. North American spec has the radio set into the upper dash with the other controls - the overseas one has the radio in a separate pod that attaches to the top of the dash.If it is a Corolla "S" - then there is a radio gap TSB that included issues relating to the trim rattling or buzzing. Unfortunantly, the fix was to add some double sided sticky foam tape to bridge the gap (TSBs are not warrantied items or the same as recalls - so you still have to pay for parts and labor).
I'd just go ahead and pull the unit myself - tape it up and see if that changes the rattling or buzzing sound.
Another issue - the face of the radio itself is pulling off the headunit - this is starting to happen on my 2003 Matrix with a 6-disc changer. The plastic faceplate is actually pulling off the radio chassis due to warping over time. Press on the faceplate and the buzzing stops, you can visually see that the plate moves back and forth. That case, can't fix it with tape - just have to breakdown and by a new headunit. You could try separating the faceplate and glueing it back onto the chassis - but with headunits as cheap as they are - easier to replace the existing unit with a more flexible, possibly better sounding aftermarket piece.
Thank you guys for the replies!
Yes it is a N. American spec Corolla Sport. The Toyota fix was to place 2 sided tape around the edges of the deck where it meets the trim?
The rattle stops if I push on either the trim at the bottom of the deck or up hard at the top of the deck where it meets the dash. I believe it is rattling against the trim.
I wonder if using some type of rubberized tape would work? Do you have any ideas as to where to place the tape, or just wrap it around the deck where it meets the trim?
Thanks again, I really appreciate the help and the kind welcome to the site!
Tim
