Our 2000 corolla just got over 60k miles. I checked the scheduled maintenance log,
? Replace engine air filter ? Replace engine oil and oil filter
? Replace engine coolant ? Rotate tires (except MR2 Spyder)
? Replace air conditioning filter (Avalon)
? Replace platinum spark plugs (Camry, Camry Solara, Sienna)1
? Inspect the following:
__ Ball joints and dust covers __ Drive shaft boots
__ Brake lines and hoses __ Engine valve clearance
__ Brake linings/drums and brake pads/discs __ Exhaust pipes and mountings
__ Charcoal canister (Sienna)2 __ Fuel tank cap gasket
__ Differential oil __ Steering gear box
__ Drive belts3 __ Steering wheel, linkage and boots
__ Fuel lines and connections, fuel tank band __ Transmission fluid or oil
and fuel tank vapor vent system hoses
Additional Maintenance Items for Special Operating Conditions:*
? Inspect nuts and bolts on chAssis and body
? Replace automatic transmission fluid
? Replace differential oil
? Replace manual transmission oil
I called the dealer for price, they told me $389. I found it later that it's their plantinum service package, not same with this list, including atf flush,etc. Since most replacement have been done in last major engine service (spark plug,oil and oil filter) or not applicable for our car, I decided to only replace coolant and air filter.
Then the inspections are still left. I felt some of them should be easy and can be do it by myself, so which one I can do , and how to do it?
Of course there are some I can't do, but I thought I can have some knowledge about them through other clues.
