Matt (fishexpo) wrote: EVAP problems are the most common ones for our years (1998-2002)- usual suspects are VSV, charcoal canister, and purge valves. Most are close to the tank. Sometimes a EVAP code is triggered by a bad catalytic converter - but usually you'll get a trouble code showing fuel trend issues as well. Bad grounds in sensors also causes issues - but those are generally much harder to find in an intermittent issue, unless you have some circuit that is completely shorted out. Sometimes these problems go away on their own or are fixed while checking on other components.The same fault codes (e.g. PO 441, and PO 446) can cover anything from a bad gas cap to cracked or leaky vacuum lines to a flooded or cracked charcoal canister. If it is definitely the canister - you should be able to pick one up anywhere from $150 to $250 brand new. Getting to the canister could be an ordeal - it is tucked next the gas tank right next to the rear subframe.
Now I read this from the faq. I recently (Nov) bought this 01 (85,000 miles). When I first looked at it and scanned it had zero trouble codes. After a week of deciding if I wanted to buy it (from brother) the engine light came on and I purchased it anyways. I got the thing scanned and it is the 446 code error for EVAP. I did notice that after driving it for a month the light went off for about two weeks. It then came back and has not gone off again. One other thing to note is that the gas mileage runs about 25mpg. Doesn't this seem low?
Any suggestions or ideas would be great I'm getting ready to take it on a long trip and would feel better having this resolved first.
